Jay R
Many if not most manufacturers say somewhere in their blurb that they don't support the use of 10440 cells in their AAA lights. I took this to assume that the circuitry can't handle it and, to some extent, they are concerned about our safety. One well known LED light website I just looked at even went so far as to say that they didn't recommend using "explosive 10440 cells". This despite the fact that I can't remember ever seeing a post about a 10440 exploding !! I can't even remember a post about a 10440 venting. Anyway, whatever your thoughts on the safety of 10440 cells I'm wondering this...
On nearly all the websites they warn against using 10440 cells but if you click onto the page for a larger torch, there is no warning whatsoever against using larger unprotected cells. They quite happily recommend using RCR123A cells or 18650 cells and make no mention at all as to whether they should be protected or not. ( I certainly know which size I would rather have short out in my pocket. ) So, it's not because of safety otherwise they would have similar warnings about larger unprotected cells.
So is it about the lights not being able to handle the power. It would seem to be the case except from my experience, they can. I have a whole bunch of AAA lights and every single one of them has run quite happily on a 10440 cell. For example, I've had every single Fenix L series AAA light and they have all run perfectly on a 10440.
You note that most of the cheap Chinese lights are stated to be OK on 10440's.
So, if it's not related to safety and if a $10 Chinese light can run on a 10440. Why do the manufacturers say my $30-$120 lights can't ? ( Even when they can.)
