Aaron1100us
I just got to thinking about this. Surefire has the Kroma with a combination of several LEDs of different colors. Why not make a single LED light with some type of color selector and different power levels? People seem to be attracted to this idea of having multiple colors. I bet most of you think that isn't possible. Well, I have something with an LED in it and that single LED can produce 256 colors, thats right, 256 colors. Its on my Yaesu VX-7R hand held ham radio. The LED is on the front panel of the radio and you can select what color you want for transmit/recieve, busy channel, main, sub plus several other options and you can even select it to stay on. It isn't very bright, not sure what type of LED it is but if you have it on white, it does work as a dim light to see in total darkness. Why not take that technology and put it into 3mm, 5mm, Luxeon, Cree and whatever other LEDs there are? If you want to check out the radio that has this LED on it, go to the Yaesu site and click on products, VHF/UFh handhelds, scroll to the right to get to the VX-7R, click files, and then the first PDF and comes up. Look on the left side where it says full color strobe LED. Maybe it isn't possible (for a flashlight) or costs too much but Yaesu did it. Imagine a U2 with a 5 watt 256 color LED. Any thoughts on this?
