Why not more love for the 26650 torchlite host?
Those of us that EDC carry the larger size lights I think are few and far between anymore aside from regular mags, which are prob only police types that EDC those at work. Most just like the smaller lights. I would like to see more big light projects myself. Though I think the other issue is that once those projects are finished, the price tags on the bigger lights are also suitably sized. There are quite a few for sale now I like to give a new home, but I simply cannot afford them so gotta go with what I can.
Waddup, can you speak a bit about this host's durability (ie waterpoofing, ability to withstand drops, proper prolonged clicky operation)? This is the first I've seen of this host, (which makes your thread title seem very appropriate yes?) and it seems like the PERFECT host for one of Nailbender's SST-50 drop ins. If it's at least on par with the quality of a Solarforce host then.....:paypal:
The host that waddup linked to will not work with any other drop-ins. You have to mount the LED to it's pill. It is proprietary to the host. You could mount a SST-50 or 90 in it though.
Below are a couple pictures of the TorchLite/ Torch Light pill compared to a standard Surefire 6P drop-in.
The Torch Light pill w/ out an LED or wires is 51 grams.
A nailbender SST-90 P60 drop-in is 19 grams.
A moddoo tripple second generation drop-in is 30 grams.
Hi, i have read and looked at 26650 sized lights with great interest. Could you tell me what off the shelf charging systems are available for these cells? I've stuck with the more common cell sizes 16340, 14500, 17500, 18500 and 18650 as i have chargers that i can simply pop these cells into and they'll charge up nicely.
Qtr, thanks for the explanation bud, I was definitely unaware that we were talking about a proprietary drop-in. Also thanks much for the size/weight comparisons between the standard P60 and the drop-in in question. I guess Fivemegas remain my best option for a 26550 host for a P60 or similar.
The Fivemega 1x26500 and 1x26650 hosts are my favorites for P60 or D36 drop-ins.
My custom coated FM host with a D36 Lumens Factory mini turbo head.
ive only owned it for about 1 week, it seems VERY strong and well built (think eagle tac), ive never dunked it in water and wont unless i have to, but guess its as waterproof as most non dive rated flashlights. its easily well built enough to make me want 1 or 2 more.
and that big old chunk of pill looks like it can take some heat :party:
beam profile with an xp-g is tight spot with plenty of flood, similar to a mag with a p7 (in profile)
im sure nailbender could custom fit an sst, mce, p7 xp-# dual/tripple cree anything you want in there.
Could you tell me what off the shelf charging systems are available for these cells.
This is the major obstacle to 26mm lights. There really isn't one. We used to get them on CPFM, but the supplier closed his tent and left, in a hurry.
its easy to make any hobby charger work tho with a clamp or some magnets.
I can charge my 26650 batteries in my Pila charger but only one at a time.
The TorchLite/ Torch Light companies make a larger head for the same body. I will post a couple pictures tonight. It is about the same size as a Mag head.
I also have two of these hosts here, one with sst-50 and another empty one waiting for another sst-50...but xp-g also sounds really good... ;) And these are great hosts :)
I charge my cells with a hobbycharger (icharger ic06+), so you can easily choose current.
I'd be interested in an extension to drive 2x26500 or 2x26650...
This is true if you want a cradle/cell holder to charge your cells, but there are dedicated chargers for this size and type of cell (size in terms of capacity and charge rate.) They are available from Battery Space and others. You can get LiIon chargers for single cells, a specific number of multiple cells (in series) and switchable units covering one to xxx number of cells.
sdnative makes well regarded cradles for multiple 18650s and has considered making dedicated cradles for 26650s. The easy short term solution is to get his 3x 18650 cradle and use the two outer positions for a pair of 26650s. See this thread for pictures and this thread for other information.
The cradles from sdnative require you to wire them up to suit your needs, but he might be willing to do that for you if you're not equiped to do it yourself. Then it's just a matter of connecting your preferred charger. That can be done with alligator clips (supplied with some chargers) or you could equip the cradle with a coaxial power socket (in-line or not, as you see fit) to mate with the in-line coaxial power plug used on some chargers.
If you're going to charge bunches of batteries, a hobby charger is a good idea. It does require more work on your part,especially initially, and most require an external power supply, but it is much more versatile than a simple dedicated LiIon charger. As with most things, decent ones are available from cheap to fairly expensive.
Whichever charger you get, you aren't required to use a cradle if you don't want to. There are various workable solutions using clamps, magnets etc. There are threads exploring a number of creative solutions for charging LiIon cells to be found on CPF, mostly in the batteries and electronics forum.
Lastly, a number of folks have found that the typical 18650 two bay chargers will accommodate a single 26650 (e.g. Pila, Ultrafire etc.) That's probably acceptable for infrequent charging of a limited number of cells.
Whatever you choose, be sure to make safety the first priority when charging!
- Syncytial.
I believe that the LightHound MKN light is based on the same 26xxx host.
http://www.lighthound.com/MKN-Cree-MC-E-Flashlight--one-or-two-26650-Batteries_p_3495.html
I recall they offered a SST 50 light a short time ago.
and if you look at the bottom of the page they show the venerable UF139 charger and LH IMR 26650 battery
Qtr, about that LF mini turbo head. Is that an early model? Looks quite different from the one currently offered.
I don't really understand what lighthound is doing..recently they sold the bodies made from fivemega for 100% more than they were sold here and if you look closer and search you will also find the torchlight kit cheaper with mc-e and sst-50.
Now THAT is a sweet looking light :thumbsup:
It's the same one they have always made. It only looks different because the coating takes away the sharp lines that are normally on it. I have a picture of the before and after coating. I also had some coated in HA III black to match my black 1x26500 C head bodies.
Lighthound is only selling an item that someone else made or bought and then sold to them. They do that with a lot of the items they sell.
Thank you, it is one of my new favorite lights. I have a couple D36 nailbender drop-ins on the way for it.
