Will a Stormproof Windmill lighter do this?
Mr. Blue
work for lighting a pipe? My pal still smokes and it is his b-day. Or does the flame not work like that.HELP!!!
A quick search on this forum would show that Windmills aren't too popular here. I have never been able to get one to work right. For that matter any high end lighter has been a frustration for me. I smoke a pipe and cigars, I use regular disposable lighters that I can pull the tops off and turn the flame waaaaaay up. You can also buy inexpensive jet flame lighters that work well for a pipe. In my experience they do everything better than a high end lighter, and you can replace them for about the same cost as the ultra pure fuel you need to refill a Windmill.
My 2 cents.
thanks...I did search and it seems some swear by them and others swear at them! lol...will the flame work on a pipe?
Yeah it will work great, a jet lighter does a better job in my opinion. I tell you another thing that works great on a pipe. You know those small jet flame things they for small soldering jobs? Works great, pretty cheap. If you are going to get him a gift, the Windmill would be a good one, it is impressive and well built. Also might check out the Bruton line, they make one with a LED light. There are two primary models in the Windmill handheld line, the Delta is higher in price and they make a cheaper version that is pretty reasonable. Lots of colors too. You will need to use a super refined fuel for these.
A little lighter porn from Patrick at tripleaughtdesign.com:
http://www.tadgear.com/x-treme%20gear/firestarters.htm
I have a windmill. It's junk. If you have any stores locally in your area with them, check them out yourself.
I tried a Vector Gear at a store here and it was a lot better than my windmill. Well built, lit every time, small, metal, but I've spent enough on fire starting things for a while.
Im happy with my Windmill JP2 lighter. Lights everytime, and has done for the 8 months ive owned it (20 a day habbit). It should work fine on pipes, the flame goes pretty much in whatever direction you point it at.
thanks boys...you all rock
Vector does look nice...but too pricey even tho he is a bud.
