Will a UV or a specific color light help me find Dog Poop
Blue72
I know it sounds silly, But I need a light to help find dog poop at night to keep my yard clean. Will a UV light do the trick or any of the colored LED?
I know it sounds silly, but you could try scooping up the poop during the day.:thinking:
Thats the problem it is not always easy to find, especially during the fall right now ( the poop camoflauges with the leaves). However my kids sneakers seems to be able to pick it up in less than 30 seconds
Perhaps buy the kids some sneakers to use to clean up poop with :naughty:
Back to your Q, I am pretty sure UV light does not show poop. It will show urine/blood.
Maybe you could feed the dog something to cause him to have blood in the poop?????:eek:
That is sick on an unimaginable way! But a perfectly valid CPF point of view.
You basically do not want an LED if you are trying to distinguish poop from brown leaves. Where colour difference and image three-dimensionality are key, you need a well-driven incandescent.
Good time to build a ROP or Mag85 I guess?
I feed mine with green trits this time of the year :eek:
Now to your Q I have some UV lights and no they don't,unfortunately.
It looks like keeping those leave off your yard,is the best way.
I could not help but laugh when I saw this thread title. But in all seriousness, are there no dog owners out there that already own a UV light to check out if it works?
You know . . . .
Back in the days when we still had a dog,
i would watch her, often from a distance, to see where she squatted.
Then i'd go get the shovel, and try my best to go to that spot.
Not always as easy as it sounds, however. :whistle:
Sometimes, in frustration, i'd notice that i could actually
Hear the Buzzing of the Flies, around the pile.
'Course, this was all in the daytime.
I do indeed share yer' "pain".
:wave:
_
Hey, don't feel bad. Up here in NW Pennsylvania I now have SNOW on top of the leaves on top of the poop.
The others are correct. Using an incan with carefully placed footsteps is the best way. The latter applies even during the daytime hours. I never tried a UV light, but I can't see it working unless there's something scary health wise in that which you seek. I have a Kroma. Colored lights will not help.
Now in my case, if we get enough snow I cut a path with the snowthrower so the greyhounds can have their own "track" to run on, and the poop.....Well, it sort of goes flying through the air in miniscule pieces right over our fence and off of our property. Problem solved.....
No need for any expensive flashlights,just shut your eyes and walk about. When you feel a squelching sensation, then you've found it!
John L
I wouldn't want to be the one who cleans your snow blower!!! :green:
Yes and I will conduct a test tonight,again.But if that fails,I will take with me a stick with a childs sneaker attached,this seems to work quite well..read through the posts.:twothumbs
Put a little luminova (from watch dials) in the dog food. It will then fluoresce brightly under UV! Or you could just have her do do what mine does, and eat crayons the kids leave around. The brighter colors are easy to spot. And Christmas tree tinsel works well too!
I trained our dog to only go in the woods around the house. He got locked in a night, then in the morn, I ran him to the woods and didn't let him leave untill he went. After a couple months, it's automatic. Now the only poop in the yard is from other dogs..........
My solution was to get a bigger dog, bigger poop is easier to find :)
Guys,
You have everything you need to find feces built in - get on your hands and knees and use your nose! Naturally, a headlamp would be helpful for identifying what you sniff out. Your nose will work even if the dog stools are covered by leaves!
<< I wouldn't want to be the one who cleans your snow blower!!! >>
LOL. Not a problem. We average over 7 feet of snow per year, so it is literally self cleaning. Four to six inches of snow so far today with numerous power failures. It's a heavy wet snow, so it is dragging the limbs down far enough to either touch the lines and cause issues or to break and bring the lines down. Also numerous pole fires and blown transformers. Translation = Flashlight time!
My dog likes to poop in multiple spots at one time and so in the dark in the fall I would sometimes spend some minutes tracking them all. I lived in at an apt complex at the time, so I didn't like using a bright incan since he'd poop near windows sometimes. I found that a blue led would work for me. Against leaves, the poop shows up because it shines more than the leaves. haha
