will Magcharger reflector fit in D mag ?
snake
HONG KONG
hello all!
Advice needed..as caption
as Magcharger reflector is Al it overcome heat problem, but magcharger use only 2A NiCad.. normal Mag allow more flexibilty on battery..
also it is cheaper then magcharger 2 ...he he
Many Thanks
Thank you ! Thank you...
so I come up another idea last night.. will a P61 fit in a mag 5C with Nimh work?
Thanks lemlux
5 cells will overdrive a P61 by a greater percentage than 7 cells will overdrive a P91. Note that SF claims that the 4-cell B65 battery will drive a P60 at 50 lumens rather than the 65 you'd get with 2 @ CR123's.
It will probably work (if it fits), but have a shorter life.
I like my P91 in a DB8AA with 7 rechargeable NiMHs and one dummy.
