Sold/Expired *Withdrawn* McLuxIII Al PD
Status
Not open for further replies.
Nake
Cleve. OH
For sale is a slate aluminum PD. It has been modded by DZ to a Seoul USWOH with an McR20-S reflector and the high setting bumped up to 750mA. It has some minimal wear on the sharp edges of the flutes and a couple of tiny dents in the rear, which can be seem in the pics. No trit slot. It has the soft spring from "Rocket Tomato", original spring included. The bezel is SS by RPM, original bezel included.
I would like $300 $275 for it, PP or Postal MO. It will ship Priority Mail USPS with delivery confirmation. Not responsible for postal mishaps. 50 State shipping to start.
Re: McLuxIII Al PD
Wow, two of these up for sale in the same week. Nice bezel on this one; should keep it safe if it hits the ground by accident. I bet that 750mA driver is nice and bright; that's even more power than the Haiku uses on high-mode.
Re: McLuxIII Al PD
Gratis bump and can you elaborate on runtimes/heat dissipation (isotropic distribution of energy :eek:) with the higher output?
Thanks
Re: McLuxIII Al PD
Just did a quick test. With an AW it ran for 41 min. before the protection kicked in. Using an IR heat gun, the temp peaked at 110F at the head and 100F at the tail after 30 min. of running with no cooling, just sitting on a table.
Re: McLuxIII Al PD
That's pretty good heat dissipation. I'm not a big fan of aluminum as a structural material, but I gotta admit it makes a great heatsink.
Re: McLuxIII Al PD
How does it do with primary cell or does it need the extra power of the AW?
Re: McLuxIII Al PD
The output is the same with a primary. It has a buck/boost circuit. The primary will probably last 60 min.
Status
