jumpstat
Withdrawn : Thank You CPF
Hi, I have no way of calculating the lumen output as I do not have the necessary equipment. However the converter is still the same stock SF converter but instead of the 700mA output, Milky has modded/calibrated the converter to produce 1A to the SSC led.Roughly how many lumens do you think it is?
Beamshots?
Will it run on 3 and/or 6 sf123's (i.e. normal m3 config and m6 config)
Thanks
Skalomax,
There is EMS (w/tracking and d/c), I think 3-5 days, I need to check first as it is Sunday today. Probably need to add around $23 more. I post the rate here after I get confirmation from the postal service tomorrow.
However, the registered airmail w/tracking and d/c is included in the price. Its much cheaper and takes between 6-14 days depending on the location. Usually it takes around 7 days. Last shipment 2 weeks ago was to the Netherlands and it took 7 days. The insurance is extra though....
Meor
