jbviau, I think you're right about the difference between the 170 and 190. The D36 170 is a P4, and the D26 190 is a Q2. I still don't understand the bins all that much, but I'm assuming P4 and Q2 are the same die, and therefore the same efficiency, just the Q2 is a little higher quality and therefore has slightly higher output, is that correct? My question then is, where are the 150 watt Q2's? :naughty: Since I want my G2 to be a simple on/off flashlight, without different modes to mess with (I plan on getting a Fenix P2D for that), not to mention the extra cost for the digital module, and the 130 lumen one's runtime should be good enough for me, and the 3.7-6v one does regulate with a single Li-Ion, I think that's the one I want to go with. But I am concerned about the beam quality, how much worse is it? And, of course, I need to be able to find it to buy it, which looks like it may be a problem.
Sgt, I'll agree the beam doesn't look good compared to the cheap ST module, in fact it looks downright awful, but how do the peripheral sidespill, build quality, and the regulation and runtimes compare?
