Tater Rocket
I have my 75 watt mr16 bulb right now, $5 at lowes. They also had three packs of 20 and 50 watt bulbs (from westinghouse) for $10, I had one of those at first, hooked up the 20 watt to my car cigarette lighter plug through a cig plug cord I have (like 10 feet long, maybe part of the problem), shined it in my eyes, didn't think it was bright enough. Same for the 50 watt. The 75 still doesn't seem THAT bright (which should be blinding, right? That is why I think I need to get the DMM and see the current draw, but my darn father took it to the apartments in his electrical box, what was he thinking? ;-) )
Anyway, I am currently taking suggestions for the casing I should use for this light. It fits quite nicely in a D cell mag casing, and the business next to our apartments is a glass shop (mom is friends with the owner), so I don't think getting a thermally-safe lens will be a problem (especially since I will need one for anything I choose to use as my case). With a LITTLE bit of sanding on the inside of a 1.5 inch slip-on PVC connecter, the bulb would fit perfectly. Then, I could take some inch and a half PVC, bring it up through the back, then use a reducer to reduce it to whatever size I think is most comfortable in my hand (this wont be too expensive, I beleive i have some inch and half PVC laying around, and the connecter is 39 cents, so maybe a couple dollars). Any other suggestions? The mag case would probably be kind of hard (and expensive, I wouldn't want to make my 4D mag plug in only, I like it being portable) to do because of the pr base holder in there. However, the bulb WILL fit in there with a pr BASE in there, so is there any way to make a connecter out of a PR base so that the mr16 bi-pin base will be able to slip in there? That isn't that important though, because I'd rather use a custom case anyway.
Do you think PVC would be able to handle the heat generated by a 75 watt bulb? Am I going to have to use aluminum or copper (do they even make 2 inch copper pipe? If they do, I'd probably have to buy a full 10 feet when I would only need 3 inches or so)?
I guess my main three problems are connecting the bi-pin base to the power (which shouldn't be too much of a problem, you can solder onto the pins can't you?), finding a suitible casing (though this shouldn't be that hard either, I am thinking a 2 inch long piece of 2 inch ID pipe reduced to 3 inches long 3/4 inch or so OD pipe for the handle and it shouldn't be all that hard to find), and also the power... Does radio shack sell the female (I guess it is, like what is normally plugged INTO, say you have your wall transformer with the cylindrical piece with the hole in middle, the thing THAT plugs into is what I need.)? Surely it would... I think I will be heading over there tonight, shouldn't be more than a dollar fifty or so.
So I guess this wont be too much problem if I can get a good case and be able to solder to the pins. What do you all think, a 5 inch long 75 watt light? Yes, it is going to have limitations having to be plugged in, but the plug I have is 10 or 15 feet long (which may have way too much resistance, which may be why it didn't seem bright enough, I will try later with a salvaged (off of a CB plug we made) cig plug and heavier wire and see if it is brighter). Suggestions... Comments?
Spudgunr
(BTW, yes, basically I could have just emailed Klaus or Phantomas since they have used 50 and 75 watt mr16 bulbs before, but hey, then I can't share with you all that I am gonna be the brightest 17 year old around here.... I can just imagine it now, this one guy at school carries a half million candle power spotlight in his truck to shine at people if they make him mad.. I can get back if I want to :) Yeah, I know that might wont have as much knockdown power because it is most likely a lot wider beamed, but hey, overall it will be brighter... (no, I don't know what the beam angle is for this light, it wasn't listed on the package)
Spudgunr
