I am having problems with my M1X tailswitch, and am wondering if a McClicky switch module would fit inside and work properly? Is there anything special going on with voltages or anything like that?
nothing different with voltages with a mcclicky -- just a standard switch.
unfortunately, I can't help you as I don't have any experience with them... good luck!
You could make it work.
It won't just drop in and go but with perhaps a slightly rigged together adapter it will work. How handy are you? Any spare materials around you could use? The toughest part will probably be keeping the switch boot just right. May have to add a spacer under it.
Good part is that you have the regular switch to copy from!
