Beastmaster
Yes, but it's rather sucky with primaries. You get about the same level of light that you did when you used the R30 assembly.
If you use a RCR123A, it's quite good. Not as good as what the E1L with final gen KL1 or the new KX1 gives, but it's useable.
So, I figure that if you use a better module that has a starting voltage of 2.7 volts, using that module plus RCR123A's will give far better performance.
-Steve
-Steve
