fenix store
- Joined
- Feb 27, 2015
- Messages
- 1,574
Introducing the New Fenix LD32 UVC Multi-Functional Flashlight
Regular Beam AND Disinfecting UV Beam for Close Range
The Fenix LD32 UVC is a new portable flashlight from Fenix that also has UVC Lighting for disinfection. The LD32 is powered by a single 18650 flashlight and has a maximum output of 1200 lumens and beam visibility of 557 feet. This new flashlight has multiple switches, one that activates the white light, and the side switches. When pressed simultaneously, it will activate the UVC light for disinfection. The high-power ultraviolet UVC light can disinfect the most common bacteria and viruses within 30 seconds, making it perfect for close-range disinfection. The UVC Light also has a protective cover in case of accidental activation. As a reminder, it is prohibited to shine the LD32 UVC light on the human body or animals and should be kept out of children's reach. Other features of the LD32 UVC include the lightweight design, sturdy pocket clip, and long runtimes. With the purchase of the LD32 UVC, you will receive a 3500mAh 18650 battery that is rechargeable via its unique USB Type-C Charging port.Regular Beam AND Disinfecting UV Beam for Close Range
