I have to pound the reflector into the mag head several times with extreme amounts of pressure. Now the bulb does not focus correctly because the bulb does not go all the way up into the reflector due to the cam not being screwed in all the way. Heres the kicker, I now cant remove the reflector because I pretty much jammed it in there.
Thanks for the heads up. I wonder if the ones from Kaidomain are any better?
I have the Kai v3 SMO and I can't comment on the cam, as I'm using it camless (w/ Kiu socket), but I also had the issues of the diameter being a bit too large for the Mag head, and it wouldn't go in properly.
I ended up taking a file and just filing down the edge of the reflector (aluminum is pretty soft) until it sat snugly in the Mag head - if this information helps anyone.
And btw, if it's jammed in there, can you not unscrew the entire head and push it out from the other side?
