F250XLT
Should have newer gen emitter(s), single mode, and run on up to 3 primaries.
NOW OPEN TO SINGLE MODE
most of the kd dropins are 9v capable. i got one with a single samsung led, mm, 3-9v.
I have a lot of Dropins but not a single one that is multi mode and up to 9 volts. Lumens factory might have something you can use.
Does it have to run on 3 primaries? Would say a 16650 and dummy spacer in you 9P work for you? Or 2X1700?
Multimode is convenient, but on typical SF 6P/9P setups with forward clicky (eg. Z41 McClicky mod) setup it's not. With such body host setups I always have single-mode modules only for simplicity, as well as Morse code capability.Just like the option to run on 3 primaries for the runtime.
