A Ace12 Enlightened Joined Mar 13, 2007 Messages 321 Apr 12, 2010 #1 Would an XP-G work well in an Argo HP?
NoFair Flashlight Enthusiast Joined Dec 22, 2004 Messages 1,556 Location Norway Apr 19, 2010 #3 Ace12 said: Click to expand... If I'm correct the Argo uses a Lux I side emitter (hourglass shaped) and the beam with a normal led like a xp-g will be crap. If you can swap out the reflector as well you should be fine. Sverre
sORe-EyEz Enlightened Joined Jun 5, 2006 Messages 803 Location Sg Apr 19, 2010 #4 hi NoFair, the older version (if still available) uses Lux 1 side emitter. the newer version branded under HP uses Cree LED. http://www.streamlight.com/product/product.aspx?pid=55 cheers.
NoFair Flashlight Enthusiast Joined Dec 22, 2004 Messages 1,556 Location Norway Apr 19, 2010 #5 If it uses a XR-E a XP-G won't give a good beam AFAIK. Putting a better XR-E in it should work fine though. Sverre
A Ace12 Enlightened Joined Mar 13, 2007 Messages 321 Apr 21, 2010 #6 NoFair said: If it uses a XR-E a XP-G won't give a good beam AFAIK. Putting a better XR-E in it should work fine though. Sverre Click to expand... I'm looking for a floodier beam anyways. I may have to give it a shot. or I might just buy an Apex Pro and mod it. Icant decide.
