eluminator
XP changed about the time I installed I.E.7. Now there seems to be a limit to the number of windows a user can have open. I usually have 30 or more I.E. tabs open and I have 10 or 15 other programs open. But then I hit a limit. No more windows or tabs will open, even the context window you get when you right click. If I right click a link in I.E. to open another tab, the context window won't appear. If I try to start another program, the program won't run, or if it does, the window will be blank. There is no error message, and no entries in the event log. If I close some windows, I can then add more until once again I hit this limit.
Occasionally when I try to start another program, I will get this little window:
I don't recall this happening before I installed I.E.7 and maybe a bunch of other updates at the same time.
If I fast user switch to another user, I can run normally and open lots of windows. I don't think I'm running out of memory and I don't think I'm running out of handles. I have 1 gig of memory. I temporarily added another gig, but the problem didn't change. Apparently it's not a limitation of the computer or of XP. It seems to be some kind of limit for a given user account. I've seen nothing about this on the internet. What is going on?
