Dear Don,
It looks like many ppl on CPF own U2's and would like to upgrade them with the new XR-E or SSC P4 led's.
It seems that the major problem with doing this is that the electronics in the U2 deliver 6-7 Volts which are required to run the stock Lux5 whilst the XR-E/SSC require only about 3-3.5V.
So my suggestion would be to put 2pcs. XR-E / SSC led's in series inside the U2 to be able to match the voltages thus also doubling ( or more ) the U2's output with the same runtime, making it a much better mod ( in my opinion ) than just replacing one led with another.
I do not own a U2 so i do not know what space is available inside the head but i suspect that if you use one of the two methods ( or rather a mixture of both ) you have already tested in other lights, it could be possible.
The two methods i am suggesting are visible in your thread here: http://www.candlepowerforums.com/vb/showthread.php?t=138418
posts no. 2, 4 & 6
A pedistal with 2 back to back XR-E or SSC P4 led's ( whichever works best with the stock reflector ) just like the one in post no. 6 would have to be made to fit the stock U2 head & reflector.
Also a custom reflector like in posts no. 2 & 4 but with two halfs could be made to fit the U2 and added to improve the beam pattern.
As i said i don't own a U2 and I am not capable of building these myself so i tot of sharing my idea with you so that you might make it a reality for others to enjoy ( if at all possible ), also because my idea was inspired from your creations in the first place.
Thanks
posts no. 2, 4 & 6
Thanks
