Yet another EBay gloat
PhotonFanatic
western Massachusetts
Twenty Sandvik SCGX inserts--list price $16.85--bought for $30. :D
Theoretical savings: $307; you've got to like saved searches for stuff you use all the time.
This obviously seems like a nice catch.
Can you help a machining noob out and tell me what they are used for?
These inserts are used mainly for turning operations on the lathe, as in reducing the diameter of a bar of aluminum, or in my case, a bar of Titanium. Yes, these inserts made for cutting aluminum are also great for Ti, since they are what are known as positive inserts, meaning that they present a sharp, angled edge to the bar. Not quite as durable as other cutting materials, but the best for easily cutting Ti, and if one gets an insert with a large radius, the finish is terrific.
Lightning strikes three times!
5 Sandvik RCGX 1810 inserts ($142 list) and a used Sandvik tooholder SRDCL 2525M 08-A (list new $120) for $40.35; seller accepted my offer.
Good job Fred. Like you I only look at Ebay for good buys on inserts. I have gotten all of my PCD inserts for pennies on the dollar, and on Al they seem to run for ever :)
Nice Fred :)
Another place that often has deeply discounted inserts is the Grainger.com Clearance Center http://www.grainger.com/Grainger/wwg/clearanceCenter.shtml
These two items are listed this morning. Quantities available vary from 1 to 1 zillion so you need to phone for availability.
Image-9853934-178753113-2-WebLarge_0_fbdfdcdec0e0045dace8d3476d78135e_1
Image-9853934-178753114-2-WebLarge_0_bdfb24a0cb236c6acc5eeacb2ab42d4e_1
Nice inserts for just over $3 each. The DNMG-432 works well for titanium turning, both roughing & finishing. Buying both a left & a right holder gives a lot of versatility to this 55° shape. Nose radius is 1/32" which is pretty broad & very strong, meaning they run for a long time in Ti. At the same time it is pointy enough to get into a tight radius corner.
Thanks, Barry--that page has been bookmarked.
Will: Insert retail prices are just a bit too much for me, although occasionally there isn't any alternative. At least I don't mind paying up, when I really need something, since I know I've saved a lot elsewhere--it all averages out nicely.
