Joe Talmadge
You probably have a light that you like best, and you consider that your favorite. But what if you define "favorite" as "the light you use the most". You might not love the light you use the most, but for some reason or other you use it. Many years ago, I mostly used a MiniMag that I wasn't very attached to due to the weak light, but the cheap batteries and fact that I felt okay banging it up meant it saw the most action. What moves the bar for you -- why aren't you using your favorite light the most? Does a picture of your perfect light emerge that's surprisingly different than what you think you want?
On the basis of use:
Third favorite: Aeon, which is actually my top favorite in terms of lights I love. I love the craftmanship, and brightness vs size ratio. I carry it on me every day, all day, but ends up seeing only the third-most use, because the two lights below fit my needs so perfectly.
Second favorite: SF L4. And I'm not even a SF fan! I use it because I run my "used up" 123As in it, so using it feels "free", plus the wall-of-light beam characteristic is so perfect for where I keep it: next to my closet, gadget shelves, and nightstand, which frequently require the use of bright flood light to find what I like. If I stored this light anywhere else, it'd never get used.
Top favorite: Orb 1W. I bet most people didn't even realize Orb made these, it was a short limited run from what I recall, aimed at primaries instead of rechargeables. It's the light I grab once I change into my pajamas at night, because it's got the tritium locator, it's small enough to carry in pj's, and has two reasonable levels of light. This means at night, whether checking on the kids, or wandering through my room without waking my wife, or just wandering about the house in general without turning all the lights on, this is what I use. It gets used every single night.
An Aeon with a tritium locator might end up my perfect light...
