roguesw
Hi guys, i have a z32 in possession, and i have a problem with it. It seems that after installing it, on both the 6p and the 9p, the flashlight would work fine for the first few times, but after a while, it doesnt work anymore, either depressing the switch for momentary on or screwing the tail cap for constant on, the first few times this happened, i thought the contacts were dirty, so i disassembled it to clean everything, but this always happens. My 6p and 9p are the original ones without Lock out caps or hex bezel, i was thinking, could this be an issue with the z32, the LA is moving about and not making any contact when the switch is depressed?
I noticed that on the Z32 bezel, it has a rubber collar, this is the shock isolation part?, it moves freely on mine.
Any ideas?
Thanks guys
Cheers and merry christmas
Des
Any ideas?
Thanks guys
Des
