Illum
my Z58 tailcap just arrived from batteryjunction after a long overdue period of back orders.
It worked great until I did my first water resistance test by allowing it to stand in the shower to simulate rain. My L6 has not been submerged in water, just standing in it.
the M3 body was bought used from the forum and came with two o-rings on the tail end. I applied a coat of nyogel 760G in all surfaces prior to the test, after the test no water was found to have entered through the o-rings.
this is where the Z58 started acting funky, it will either not light up at all, or it will only light up when the tailcap is tightened down to a specific point, sometimes just before lock-out, other times just before its fully tightened. From tht symptom I'm inclined to think its not a contact to body issue, its something inside the tailcap thats causing this.
The clicking sound did not change, no fluids have been shooked out, and there are no loose pieces that can be heard before, during, or after the click
the tailend was shorted and the light works, so I know for sure its a matter of a bad tailcap. I'll be using this light in part to a Halloween event so I am not going to be able to acquire a replacement in time even if I do call surefire.
Has anyone had the same problem with the Z58 and was anyone able to fix it? from the design I doubt the tailcap can be disassembled but for now I'm out of ideas. :shakehead
