mdocod
I'm having so much fun with these lights I just had to write up a review on them...
Both of these lights attracted me because they use easy to find "C" size cells.
Both lights have a single power level (On, no medium settings)
Taskforce- ~$40
The Taskforce uses 2 C size cells and has a "star" style 3W luxeon diode. It has a regulator of sorts in it. So brightness remains similar throughout the batteries life. It is built fairly well (feels tough), and the threads operate and line-up fairly well. I didn't find any "burs" or evidense of poor machining here. The grip is a nice "knurled rubber" style sleeve that feels good. The head of the lights has some "heat-sink" looking ribs with indentations that serve as "anti-roll." It comes with a decent little belt carrier and strap that attatches to the rear. The bulb seems to be mostly focused by a lense, and therefor, has very little "spill" in the beam... just a nice "blotch" of light. The button is on the rear.
Pros: regulated, uses easy to find C size cells, built decent, easy to find at lowes, rubber handle, good "click" action in button.
Cons: batteries rattle inside when shaken, lack of spillbeam(could be a pro for some people) and no adjustable beam, button looks to be a weak point for water resistance.
LEDbeam- ~$25
The LEDbeam uses 3 C size cells and a non-star style emitter. There is no regulation in this circuit, so it gets dimmer through the duration of battery life, however, NIMH would probably reduce this problem. The build quality is lower than the taskforce- It body is made from thinner metal, and the threads aren't perfect. (they squeak/grind and are hard to operate freely and lineup) The threading also had some minor burs. Some silicone would help this flashlight out a lot. However, I do like the "looks" of the flashlight. It is an example of elegance through simplicity. No fancy design here. The handle is in the form of a lightly knurled section of the body(not rough). The head is simple and shares the same simplistic look of the rest of the light. No anti-roll here. The bulb is focused by the reflector entirely, no lense is used here. The result is a typical spillbeam and tightly focused spot in the center. The beam is adjustable by spinning the head- however... the beam generates "rings" when it is adjusted out of "spot" mode, but overall, it is brighter than the Taskforce. The button is just behind the head on the body. I also wanted to mention, that out of the 3 lights I got, 2 of them seemed to be a "white-blue" color, and 1 of them had more of a greenish tint to it. The light output of the 3 is very similar however.
Pros: Uses easy to find C cells, brighter than taskforce, adjustable beam, good amount of spillbeam, excellent value (very cheap for a 3W LED).
Cons: Batteries rattle when shaken, poorly machined threads, when adjusted out of "spot" the o-ring that seals between the head and body would probably not be in "contact" well enough to repel water, lack of regulation circuit. "Ringy" beam when adjusted to flood.
Conclusion: I like both of them, and both lights seem to be good "values." However, I like the LEDBeam better purely on performance/price ratio. You get more light and an adjustable beam for less money. I can live with the cons easily when I consider the price.
now... for some fun- BEAMSHOTS (ooooo, ahhhhh)... (and some more oooo, ahhhh)...
side by side, taskforce left, ledbeam right.... against a door on the floor.
http://photobucket.com/albums/b72/mdocod/flashlights/?action=view¤t=100_1644.jpg
again- side by side with TF on the left, this time with them both pointed at a wall from about 2.5M away. (The wall is painted blue). The ledbeam is focused tight.
http://photobucket.com/albums/b72/mdocod/flashlights/?action=view¤t=100_1646.jpg
same as before, but ledbeam is fucused a little wider.
http://photobucket.com/albums/b72/mdocod/flashlights/?action=view¤t=100_1647.jpg
I should point out that most of the "ambiant" light in the beam shots against the wall was produced by the ledbeam.
i'm still trying to learn how to use this camera.... if I were better with It I could take individual shots of the beams, with the camera set "the same"... but for now, i put them side-by-side to ensure that the auto-settings would not effect comparisons of brightness.
This is my first "review" of flashlights... so be gentle, lol.... hope this was usefull for someone.
Taskforce- ~$40
LEDbeam- ~$25
