Help with Resistor for LED
litlmh
Bay Area, CA
I was seeing if anyone could help me check these calculations, since I'm not sure whether I'm doing them correctly. I already did a search and found this thread, which helped me a little.
For this flashlight: http://store.advancedmart.com/5wamesiledfl.html
There is a review at FlashlightReviews which speculates that it is using an 8mm 100 mA LED (http://www.powerleds.com/data/pro4.html). Another review measured the current draw at 91 mA, so that seems correct.
Since it's a direct drive flashlight, modifying it to use NiMH batteries means that it needs a resistor in series, right? So here are my calculations:
Since each NiMH battery starts at about 1.4V, 1.4V x 3 = 4.2V
LED operating values: 3.2 V @ 100 mA
4.2 - 3.2 = 1V drop
Using V = IR,
1V drop at 100 mA = 10 Ohm resistor
Does this seem correct? Any help would be greatly appreciated. Thanks in advance!
nemul
Georgia
sounds right.... but wouldn't that 1.4 drop to 1.2 pretty fast? 4 Ohm?
3.6/3.2 10 ohm = 40mA
3.6/3.2 4 ohm = 100mA
i think...
litlmh
Bay Area, CA
Does that mean I should use a resistor with lower resistance then? Won't that cause the LED to be hit with a lot more current until the voltage of the NiMH drops to 1.2 V from 1.4V?
Is it safe to run a LED at currents above absolute maximum ratings?
AuroraLite
HK
4.2 - 3.2 = 1V drop
Using V = IR,
If we are certain that the LED is operating on 3.2V @ 100ma (which is not overdriving it at that voltage or current level),then
V = IR
(1V) = (100ma)*R
R = 1/0.1 ohm = 10 ohm,
and I think it is correct. :)
Unless we are drianing the batteries high up to 500ma+, it shouldn't be a very severe drop from the beginning(the battery voltage sag), and I believe the discharge curve might look like one from the MJ leds(which is a flat very gradual slope)
And if we were to assume the operating voltage for the 8mm to be remained around close to 3.2v with higher current, then if we were using lower value resistor(say 5 ohm):
V = IR
(1V) = I*(5 ohm)
I = 0.25A = 250ma.
It will most likely severely overdrive the LED and might even permanently damage it.
Should my calculation is indeed incorrect, please also feel free to correct. :)
