ixus_123
The Background
I mainly cycle in London so along lit roads & generally only need a 'be seen' light & that's what I had for the most part - some form of Cateye LED light. Riding home one night I took the canal route - faster becuase of no traffic lights. Cruising at about 20mph, I suddenly found my wheel had found a crack in the towpath & was guiding me to the water. I tried to lift the wheel & steer out but it was like I was on rails. With 4kg of locks on my back, I didn't fancy my chances in the water, so I took a drop to the landside. Not a great experience so Idecided i need more light for my canal shorcuts.
The Solution
Brighter Lights so I can see where I'm going. Thing is nothing really offes what I'm after so I decided I want to make my own. Found loads of links on homemade halogen systems but with a typical journey of 2.5 hours , I don't fancy the battery weight. LED seems like a great solution!
My main Inspirations during the six hours I've been online researching are Nightrider's Dual Luxeon V light & Electrolumens Quadstar Bikelight
My Problem
I don't really understand the electrical side of things. I've tried researching things but I just don't get it & was hoping some of you might help.
So far I am planning to run 6 1.2 volt 35003mAh in series to give me 7.2 volts like the Quadstar. I want to run two 3w luxeons (in series?) - is it just a matter of connecting the to the battery or will this method risk damaging the LEDs?
If I can't hook up directly to the battery do I need to run one these things?
Konlux Constant Power 350mA / 700mA / 1000mA / 1050mA / 1400mA
If I do need one, which one? I'm guessing it's a shootout between 700, 1000 / 1050(?) & I guess with 1000 I'll get more light than 700 but then I thinkg the LEDs draw more current so would I need another C cell to bring me upto 8.4 volts?
Also, do I need to place a fuse close the battery & if so what rating?
I really have no idea on this part & want to be as clear as I can before I place my orders so that I can order all my parts in one sitting & hopefully have them all arrive at more or less the same time.
I know it's a bit long winded & perhaps blining simple to those that know so thanks for your patience
The Solution
My Problem
