Thanks for your advises guys ! I think I'll try to live with that, the hole isn't so big, I jus was disappointed to see it on a new surefire light...
Also, I worked severall hours to take that motherf...... piece of plastic insert out and there are so marks on the inside
so I don't think surefire would replace it now :mecry:
But I take the opportunity of this post to let you know another way to remove safely this plastic insert :huh: :
Finally, as the insert doesn't seem to go out by freesing or with acetone, I had a great idea
: I put some Utile plast inside :
http://www.wired-2-shop.com/joneakes/ProductDetail.asp?ProdID=457&nPrdImageID=&CatID=1
When it was hard enough (after 10 minutes), screw inside it (so that the now hard plastic wouldn't sleep out), then put a screwdriver on it and pushed it out with a hammer. After that, put the plastic insert (with the Utile plast in it) in hot water so you can get the plastic out again an re-use the plastic insert. That's it ! :bump:
