Hey guys,
I have a few light bodies for sale...
First is this one...
This is for the light body only. It is turned of aluminum bronze and is sammie compatible. It has a brass collar, mineral glass lens, and IMS 17mm reflector. I actually carried this one for a while, so it has a couple of dings in it, but I couldn't capture them in the pics. My camera sucks. It is a single speed light, although I did run it for a while using a POP based sammie and a li-ion batt. It runs on 123 size batts. I'm asking $125 for the light body including shipping via either Priority mail with DC or Global Priority. BTW, the price does not include the McGizmo clip.
***SOLD***The second one...
This is a Cr2 based light. With this one, it is what it is. It has a home made light engine in it that is of a non standard size, so you can't swap it out, unless I make you another. It has a MadMax+ converter with a TWOH sitting on top of it. It is also turned of aluminum bronze, with the light engine being made of aluminum and brass. It has a mineral glass lens and McR16 reflector. I'm asking $225 for this light, including Priority Mail with DC or Global Priority Mail.
The emitter that I used is a joker. Before turning a bit off of the bottom of the reflector, I just put it together to see what it looked. After seeing the beam, I decided to leave it alone. Although the beam is a bit less intense, it makes a beautiful transition from hotspot to spill and really lends itself to types of situations for which you might use a light this size.
***SOLD***The last one...
Again, this is an aluminum bronze light. It is Cr2 based and is Aleph LE compatible. This is for the light body only. It has a mineral glass lens, with a McR16 reflector. This light is a bit unique in that you twist the knob on the back to turn it on. Although I haven't tried it, I'm sure that it will work with a POP based LE and li-ion cell. I'm asking $175 for the light body, including Priority Mail with DC or Global Priority.
A note about this light is that I have it spaced to run properly according to the way that I put the button on my Light engines. The way that I do it is to make the solder blob, or button, even with the bottom edge of the can. If this is a problem for you, I'll "fix" your light engine, free of charge. If you need an LE, ask about it.
If you want one of the above lights, just post with an "I'll take it," and PM me for payment details. FYI, I accept payment by paypal and I do charge 4% for credit card payments.
