Yes, the Eos has no heatsink!! It does have a heat regulation circuit for 'high' mode, so when the LED get too hot it backs off the current a bit...That means a dimmer light... the hotter it gets the more it backs off the current...
Adding a heatsink helps to lower the temp on the star's MCPCB, so the heat regulation circuit kicks in later, if at all...
So when swapping out the LED, just cut out a piece of copper or alloy, the same shape as the gold section & the same thickness as a 1w star board, remove the tab that holds the star up & insert the heatsink. I used 3/4 's of a star board for my heatsink, the overall height is spot on!!
A bit of expoy on the star stops the heatsink from moving around...as the optic holder holds the star in place.
A little heat gets to the board, but thats alright as when they get made they go through an reflow oven @ 100's of deg, so a little heats is not a problem...
***when removing the star from the Eos, it pays to snip the leads to the glass diode stuck to the star's underneath as on the more recent versions this has been stuck good, & the diode has broken when removing***
You then have to remove the diode from the star board, with a sharp knife...
I also frosted the optic on one of my units...very nice wall of light, but no punch...
If you break your diode, let me know, I can supply a replacment part, i have been testing, so far so good...
enjoy
Ktronik
enjoy
Ktronik
