bippidie said:Gransee,
I remember reading in older posts (now in the archives, I believe) that you recommended a Radio Shack lubricant for the threads of the Arc AAA. Do you have a part number on that? thanks in advance.
bippidie
greenLED said:A quick Google search yields: RatShack Lube Gel
Alloy Addict said:I went to Radio Shack and bought some of this Silicone Lube Gel. It worked really well, so thank you for the suggestion. The 3 oz. tube should last me the rest of my life unless it degrades or I use it for something else.
It was marked as "Clearance," so I asked the employee if that meant it was discontinued and he said that it "could" mean that. Has anyone else heard this?
vortechs said:I just picked up a tube of RadioShack Multi-Purpose Lube Gel (64-2326). It was marked clearance. The clearance price was $0.97 and there was a 25% off promotion on all clearance merchandise, making the price $0.73.
It is good to know that this stuff is recommended.
Its called Lube Gel. Its available just about anywhere, sporting goods stores, tool supply houses, gunshops and hobby shops. I have a 3 ounce tube of it I have been using for ten years or so on just just about everything I have that has O-Rings. I figure it should last me another 20-30 years. I have tried all of the silicone lubes and I always wind up back at the Lube Gel.mezzman said:I have been told that the radio shack lube is discontinued and all remaining stock is whatever is left on various stores shelves. If you search the product number on their website it will tell what stores in your area have it in stock.
