Paul_in_Maryland
Pelican Products has just introduced the 9V, 3x123A big brother of the Pelican M6 (PM6). Rather than discuss the new light in various threads, let's consolidate all comments here, as we did in 2004 for the Costco 1W LED.
As of this first posting, the M3 doesn't appear on Pelican's site. But you can see it at a vendor's M3 page.
Some highlights of the Pelican M3, or, "PM3":
- 140 lumens
- 13 watts
- uses a fixed lamp assembly (Pelican 3374)
- 7.5 inches (~190mm) long
- 11.1 ounces (~315g) plus cells
- Draws 1.61 amps (not the 0.61A stated on the vendor's page)
- Priced a bit below the Streamlight TL-3, its direct competition.
- Available in black (3374B) or green (3374 OD?).
- Will the 9V lamp assembly fit the PM6 body?
- Will the 9V lamp assembly interchange with the LED module in the M3 LED?
- How does the throw compare with that of the PM6? the Pelican M3 LED (PEL3770)? the Streamlight TL-3?
- Can the lamp be single-clicked ON with various protected 17500 cells? Double-clicked ON? Or will it require 150S/150B/300S cells from Pila, Wolf Eyes, or Microfire?
- Can the lamp be run from a pair of unprotected RCR123A cells?
- Will the lamp assembly fit any other flashlight head?
- What other lamp assemblies will fit the PM3 head?
- Will a Surefire P-type tailcap fit the PM3 perfectly, as it will fit the PM6?
- Is the PM3 identical to the TacStar T9? If not, how do they differ?
