Please see Inova X1 Spot Blue for my previous comparison -
This X1 Spot White was a "win-win" trade with CPF member Lee1959 - who got this out to me about as fast as humanly possible on Friday 3/24 - when we discussed it,
and it was in my mailbox on Monday 3/27 - Lee, and USPS be praised........
Size
Heads
Shining this white spot X1 around during the daylight - I was somewhat disappointed - it just didn't seem as bright as my experience with the Blue Spot.
Well it kind of stands to reason -
first, the blue is a very noticable color, it provides color contrast - so that one can mostly see it even in lit conditions - whereas a "white" will often not be as visible.
Also my understanding is that "white" LEDs start as blue and use phosphor to transform/re-emit the light as "white" - so all things being equal a blue LED would be unhindered and therefore brighter.......
OK getting over my initial disappointment, and realizing my over-expectations - how does this white spot X1 do?
vs. River Rock 1.5w 2AA Spot
The River Rock 1.5w 2AA is easily brighter as can be seen in the beamshots -
again because both these lights were just spots without any significant side-spill, a close 9" beamshot did not make sense - so I backed up the lights to ~1.2metres (~4ft) from the paper target surface.
Here's a color DEsaturated version of the -2 stops underexposed beamshot for direct comparison with the Inova X1 Spot Blue -
vs. Dorcy 1AAA gen3 Spot
The X1 white Spot has a significantly more intense and concentrated spot than the Dorcy 1AAA gen3 spot. The difference was about the same as the difference between the X1 white Spot vs. River Rock 1.5w 2AA spot.
This shows that the X1 Spot White's performance is still pretty respectable/impressive.
I think it was just my over-expectation that led to my initial disappointment - afterall this is just a humble single 5mm white LED.........
So let's get right back to the over-expectation lane -
vs. Fenix L1 v2.5
obviously not as bright as a good reflectored 1watt Luxeon -
again this beamshot is at ~1.2m/4ft so really only showing the hotspot of the Fenix. The Fenix L1 obviously has a lot of side-spill not shown by this comparison - again this shows the X1 Spot White does acquit itself reasonably well - just not as well as the Blue Spot........
Back to reality -
the X1 Spot white obviously does not rival a 1.5watt Spot or 1watt reflector - com'on what did I expect?
But it is comparable to the hotspot of a good 1/2watt -
vs Nuwai 0.5w 1AAA (TM-310H)
The concentration/focussing/collimation of the light into a spot does rival the hotspot of a good 1/2watt. The Nuwai TM-310H 0.5w 1AAA does have a very intense (blue tinted) hotspot and this X1 spot white does rival this kind of level.
Here's also a color DEsaturated version of the -2 stops underexposed beamshot to show that the hotspots are comparable -
OK - realistically the Inova X1 Spot White does well for a 5mm White LED - it does concentrate/focus/collimate the light into a relatively intense spot - which at first sight seems a bit brown/yellow/pink/red in tint/hue - there is a characteristic blue ring - that seems common to all the lens spot lights I have (albeit limited - River Rock 1.5w 2AA and 2C; Dorcy 1AAA gen3 Spot and this Inova X1 Spot White).
The light within the spot is very even - which leads to me seeing very well - almost like a "high-definition" light. Shine any of these lights on to a fine pattern surface (wallpaper) and compare directly with almost any reflectored light and the pattern inside the spot just seems much better defined to my eyes.
Don't get me wrong, the reflector light(s) will show the pattern - but because of the inherent differences in the brightness levels - even (or especially) in the hot spot(s) the pattern is just not seen as well - I am almost certain it's not just my eyes.
However having said all that - a reflector light is almost always going to much more generally useful - as they have much wider coverage and one does not have to constantly pan the light around to see.
The Inova X1 Spot White is definitely a compromise - but it's done about as good a job as the limits allow.
For example I like the much wider spot of the Dorcy 1AAA gen3 - but because the light is spread out more - it generally looks dim - so for general use it doesn't quite make it. For closer tasks it actually is pretty good as I am finding out.
The X1 Spot White has a much more concentrated spot - and its brightness over longer normal distances is only just acceptable - but the beam is just way too narrow for real general usage - and for closer tasks it is just too bright (for my eyes) - so kind of a "worse of both worlds" - one can understand why this version was so UNpopular.
Whereas the 1.5w River Rocks are about the right sort of level for the (longer) normal distance usage..........
So in conclusion - I like the the X1 Spot White - because it is "different" - but also realize because of being a spot it is of limited real use for me - it is not as spectacular as the Blue LED - but again white is much more generally useful - for me.
The new reflector X1 - would be much more generally useful - but I already have lots of 5mm white LED lights using single AA or AAA that are just as good, or better in some ways for me -
the new reflector X1 shows no overall advantage, and it is over-priced at $20.
Whereas the seemingly unpopular X1 Spot White still manages to do something for me - despite (or maybe because of) its eccentricity and I know it's supposed to be "inferior" to the reflector version........
Size
Heads
vs. Fenix L1 v2.5
Back to reality -
