ADDICTED2LITE
I need a PR base LED bulb with a lot of sidespill. Its going in a lantern I found with 4 AA batteries. It doesn't have to be really bright, the longer run time is more desirable.
Can't answer that with certainty, since I'm no engineer. I'm guessing this would be a more involved mod than the one I suggested. These cheap lanterns are relatively easy to rewire, if they are anything like the ones I've seen.TrueBlue said:You could get creative and wire two PR SMJLED bulbs in series. You'd get twice the brightness because you are using two bulbs. The combined bulbs would run on 6 volts.
I think that would work, wouldn't it? :thinking:
The new version everLED (has a dot on the PR base) are reverse-polarity protected, IIRC.LEDninja said:CHECK THE POLARITY OF THE LANTERN BEFORE BUYING BULB!!!
Shirley said:Will those SuperBrightLED replacements work in Mag Lites?
WelcomeShirley said:Thanks for the reply.
Shirley said:I also got a red LED (PR2-R2-4.5V RED LED FlashLight bulb)
from them, besides the variable input bulb you mention. I figure, for the price, I don't have much to lose! Wonder if it'll work in a 2-cell...
Yes.Shirley said:LEDninja,
I just tried mine in a 2AA Gelbrite. Too dim to be useful.Shirley said:I also got a red LED (PR2-R2-4.5V RED LED FlashLight bulb)
