luxlunatic
Completed my first build of a ARC LS. Started with a bare, empty 123 twisty body form cy, and decided to do a direct drive of a LUX 1 cyan from photonfanatic.
Used a thick chunk of brass to dissapate heat(nasty solder job!)
A little foam to curb battery rattle.
Used a McR18 reflector from The Shop, that I spilled something on and the texture came off, so I had to sand it out and pollish it up.
Decided on a diffused lens from Flashlightlens because cyan color can be quite hard on the eyes, when intense.
Pollished it up to a nice finish.
And a beam shot from about 4 feet off a white wall.
Nice flood of cyan light that is BRIGHT! Good throw as well. Gets about 25 minutes of run time on a RCR123 before it begins to visually drop off. Gets hot pretty quick, but I figure that means my heatsink is sinking the heat away from the led in a hurry. Very happy with the way this turned out. Next up for one of my other LS's, I'm thinking of driving a SXOH LUX1 with a Flupic, powered by a CR2 using Bombelman's CR2 adapter, the more efficient emmiter should be a good match with a RCR2.
