Silviron
OK, I\'ll start this off with a HOMEBREW
Pictured here with a 2AA MiniMag Light, my CPLS1 copper pipe / Luxeon Star with Optics LED flashlight is powered by three 4/3A sized NiMH rechargeable batteries with a capacity of 3,800mah. These batteries are normally used in laptop computer battery packs, and have a pretty high energy density. The flashlight is almost exactly 12 inches long, and is made of 3/4 inch (heavy wall) copper plumbing pipe and fittings.
Has a 1/2 ohm 1 watt resistor in series to provide some over-voltage protection from freshly charged batteries which usually have 4.2 to 4.3 volts on them unless it has been "laying around" off the charger for a few days.
The "head" between the LED heatsink and the top of the batteries is filled with heatsinking epoxy.
You could probably get away with not using the resistor, but I decided to add it for increased reliability, even if it lowers brightness a bit.
After the light has been on for about 15 minutes, the whole thing makes a nice handwarmer
. It doesn't get uncomfortably hot, (Well within limits of the LED) but you would appreciate it on a cold, windy night.
BEAM COMPARISON pics:
LONGEVITY:
I have run three cycles of charging and then continuous operation of the light; Here are the AVERAGE of time - light output figures. Figures are in LUX and the first one is measured with the light 1 meter from the sensor, and the second figure is with the light in contact with the sensor:
Initial (fresh charge): 261.5 / 77,150 LUX
1 Hour: 244 / 69,800 LUX
2 Hour: 229 / 67,850 LUX
3 Hour: 223 / 67,100 LUX
4 Hour: 215 / 66,900 LUX
5 Hour: 203 / 60,200 LUX
6 Hour: 75.5 / 21,000 LUX
7 Hour: 29 / 9,000 LUX
After eight hours the light output falls to about 10 LUX and SLOWLY tapers off to 2 / 600 LUX at 24 hours. This is enough light to get around a dark house or even out of a cave if you move slowly.
Light has jack to plug in a "wall wart" trickle charger. The one with the light is only 75ma, so it can be left on charge indefinitely. Takes about two days to reach full charge from full discharge, but a higher ma or A 4VDC supply will charge it faster.
LONGEVITY:
