KDOG3
I got my emitter and the 2-part ArcticSilver thermal adhesive today. I got this to replace the awfully purple-tinted emitter on my G&P 3W drop in. So here we go! First, what tools will I need? I'm pretty sure I'll need a soldering iron. Hopefully I can get a fine point one if it exist. Is there a certain kind of solder agent I should use or will plain ol' solder work?
I noticed on the existing emitter there is this white goop around the base of the emitter where it attatches to the heatsink. Its' also covering up the leads. What do I use to get that gunk off? I also don't see a positive or negative indicators on the emitter. If there is none, do I take that to mean it doesn't matter which lead is going to a given contact? I certainly don't want to blow it up.
The 2 part adhesive, what is the procedure for mixing/using that? I assume that goes on the bottom of the emitter which is then placed on the heatsink where the old emitter was located?
Also, I have some Arctic Silver thermal paste as well as the generic white goo (presumeably silicone based). Which should I use to go around the base of the emitter after its attatched to the heatsink? Do I even need it?
This will be my most difficult mod to date, I'd really like it to be successful! Thanks for any help you guys can give me!
