JT:
Carley regrets that their aluminum reflectors will not fit into Mag heads.
I haven't yet used the Carley reflectors but am on the verge of ordering a total 5 @ 2" and 3" set screw reflectors. I will epoxy 2" Mag charger tempered glass lenses to make 2" reflector lens assemblies. Carley said they'd give me the name of their supplier of 3" lenses and "faceplate" parts. Depending upon what develops from this lead I will either buy 5 @ 2" assemblies or 2 @ 2" and 3 @ 3" reflectors at a quoted unit price of $6.13 @ and $14.37 @, respectively.
I will find a way to insert at least two of these into modded DB heads. The others will go into project lights with multiple 2450 mAh 7.2 V A battery packs.
BTW, I just received Carley's quote for potted bulbs today. It follows including the potted #809 bulb I mentioned priced at $7.52 @ or $1.23 more with Voltage and Amperage inscribed.
"6-27-02
HI,
I HOPE THIS FINDS YOU WELL. SORRY FOR THE LING DELAY IN GETTING THIS TO YOU.
I HAVE TWO OPTIONS FOR YOU. ONE IS TO HAVE THE LAMP POTTED INTO THE PR BASE
WITH NO BASE MARKING AND SECOND, TO HAVE THE LAMP POTTED WITH THE MARKING OF
VOLTAGE AND PART NUMBER ON THE PR BASE.
CL 809 POTTED ONLY - $ 7.52 EACH
CL 809 POTTED & MARKED - $ 8.73 EACH
CL 851 POTTED ONLY - $ 8.02 EACH
CL 851 POTTED & MARKED - $ 9.23 EACH
CL 1122 POTTED ONLY - $8.02 EACH
CL 1122 POTTED & MARKED - $ 9.23 EACH
CL 928 POTTED ONLY - $ 7.36 EACH
CL 928 POTTED & MARKED - $ 8.57 EACH
LEAD TIME PROVIDING ALL ITEMS ARE IN STOCK IS 4 - 6 WEEKS.
IF YOU HAVE ANY QUESTIONS OR WOULD LIKE TO PROCEED WITH AN ORDER, PLEASE
CONTACT ME.
PLEASE REMEMBER WE WILL BE CLOSED THE FIRST 2 WEEKS OF JULY 02 REP OPENING
ON THE 15TH.
HAVE A NICE 4TH. TAKE CARE."
