Alin10123
Hey guys,
I tried to search for MCes2 but didn't get very far after going through about a whole page of threads. I see that the complete switch is no longer available for the L4. It's still there for the "classic" series. Is that the same as the "E" series? or will it not work?
I do see that there are a few "diy" kits left. Are those hard to assemble? I also noticed that there are several different resistance choices. Which one would be best for me? I would like it dim enough to read without glare, but still be able to use it in "low" and have sufficient lighting to safely navigate around the inside of a house that's under construction. (just an example)
How do these switches work? Is it click high, low, off? Or is it when you click it's high/low and then you unscrew the tailcap to turn it off?
Will these work with the standard cap that comes with the L4 when it's purchased? I didn't see any "accessory" tailcaps on surefire's website.
By the way, there were several 2 stage tail cap DIY kits on the website. Which one is right for me when i do the mod? Do i need a new rubber cap or anything?
thanks in advance, i've been reading for 2 hours on this and haven't found anything relevant to what i need.
thanks
thanks
