tarsier
- Joined
- Jun 9, 2006
- Messages
- 22
I have an old surefire z3 combatlight - any suggestions on Mods?
tarsier
tarsier
sween1911 said:I had some trouble with the Z32 shock iso bezel mounted on my Z3. Every now and then, it would fail to turn on if I shook it around a bit. I think the shock absorbing foam would allow the lamp to ever-so-slightly move out of engagement with the battery. Not a big deal, but it would bug me enough.
I do have a black M2 bezel on mine now and I like it. It's worked 100%.
Pyrex being tempered glass will not melt nor scratch like Lexan can.cue003 said:Out of curiousity Al, is the pyrex better than the lexan lens?
The Z3 uses the standard bezel (same as the 6P) which features a Pyrex window.cue003 said:What comes with the stock Z3 head?
Apart from the window being Lexan rather than Pyrex the Z32 is a bit longer and wider diameter to be able to contain the shock isolation components.cue003 said:Is the shock isolation the only difference between the stock Z3 head and the Z32? Is one head smaller?
Size15's said:The Z3 uses the standard bezel (same as the 6P) which features a Pyrex window.
Too bad that you weren't on CPF a couple of weeks ago when I gave away two Z44-BK hex bezels with Pyrex window.sween1911 said:Hrm.. the Z3 I bought had the hex bezel but with the Lexan press fit lens. I don't think they made the cut when the switchover to the Pyrex lenses went into effect before they were discontinued.
Size15's said:The Lexan window is more likely to be damaged by the heat generated from using the P90/P91 lamps constant-on for long periods.
Al
I replaced the bezel on my Z3 with the Pyrex window Z44. I prefer Pyrex for it's scratch resistance, in addition to it's thermal resistance.cue003 said:If there is no output benefit (not talking light meter reading here...real world) from using the Z44, why spend the $20 on it unless your existing setup is damaged?
Just curious.
Thanks.
Curtis
