lemlux & Streamchucker -
lemlux, above you mentioned: "The 808 will be underdriven to something slightly below 285 Lumen" (with the 4 cr123's pushing it). So can you recomend a Carley bulb that would work with the 4 cr123's being overdriven, so that it would produce even more light?
Also I started sizing up my light for this mod, and I seem to have messed up my CR123's. The 4 of them are a really tight fit in there, and I seem to have pushed in the bottoms of the batteries. Has this happened to you as well?
And, lemlux stated the following talking about putting the 4 CR123's in to the 2c-cellMag: "You need to remove the spring from the endcap, grind down the inside-endcap annodizing for electrical contact, and use tubing a little shorter than 3 123's long to position the 3 batteries that aren't in the endcap."
So what are you doing with the 4th battery? Is it just staying in there from the tight fit?
Because the bottom of the CR123 is recessed, do you need to put some aluminum foil under the last battery and the end cap to make contact?
Thanks -
