abvidledUK
Nice if someone could do a comparison between these torches !!
Output and RT my main questions.
You might want to re-check your calibration. 20,000 Lux at one foot would be about 2000 lux at 1 meter, i.e. 2000 cd beam brightness. That's a lot higher than the 800 cd that FLR measured for the same light.abvidledUK said:...My personal output readings are:
UF601........13.1...RT...3.5...hrs
L2P............12.9...RT...4.0...hrs
L1P............12.1...RT...2.8...hrs
UF602A1.....11.9...RT...1.8...hrs
UF602........11.0...RT...1.5...hrs
No LF1 to test...
Readings torch 12" from Lenin 4 Photographic lightmeter, as per all my reviews.
11.0= 5,100 lux
12.0= 10,000 lux
13.0= 20,000 lux
chevrofreak said:If anyone has a 602A1 and some 14500 Li-ions they'd loan to me for some runtime tests I'd be glad to do them.
I've been drooling over the 602A1 for a while now, but dont want to buy one until more is known about its performance.
nerdgineer said:You might want to re-check your calibration. 20,000 Lux at one foot would be about 2000 lux at 1 meter, i.e. 2000 cd beam brightness. That's a lot higher than the 800 cd that FLR measured for the same light.
Just a thought...
A good point. I was only commenting that abvidledUK's conversion of EV readings to brightness (LUX at one foot in his case) appeared to be much higher than FLR's measurements for the same model light.TornadoKat said:...However, for a focused light source you have to know the beam's angle of spread as well as the two measured distances... the tighter the beam, the less you would lose from a foot to a meter. If you had a perfectly focused beam that didn't spread at all, the measurement would be the same at a meter as it was at a foot because the sensor would be receiving the same amount of light...
nerdgineer said:A good point. I was only commenting that abvidledUK's conversion of EV readings to brightness (LUX at one foot in his case) appeared to be much higher than FLR's measurements for the same model light.
The point source approximation suggested that abvidledUK's measurements were almost 3 times higher than FLR's measurements.
