I am curious about using white LED and red lenses. If I understand correctly, white LEDs should only be emitting blue and yellow light. "Real" white light is made up of a mixture of all colors.
The way I understand it, a red lens or filter works on white light by blocking all the colors except red. Consequently you see red light through the filter.
This leads me to my question. If a white LED contains only blue and yellow light (no red) shouldn't a red filter prevent any light at all from passing through? I have tried shining white LEDs through red filters and the light seems to pass through just fine.
Does the LED contain some red light? Perhaps the filters are not capable of stopping all non-red light, but if this were the case, shouldn't I see the white and yellow rather than just a red glow from the filter?
I suppose the thing to do would be to measure a white led and a white incandescent of equal intensity through the red filter to determine if the light that passes through is lower for the LED. I don't have the capability to make this measurement.
Any thoughts?
Any thoughts?
