rgbphil
Hi,
I'm evaulating the thermal design of two arrays, one of seven equi-spaced (ie a hexagon) Osram Golden Dragons, and another of seven Luxeon K2s.
Without having to cut into the PCB to get at the heatsink slug, can anyone offer a suggestion to measure the Junction Temperature of these devices?
For the GD I've soldered a thermocouple to the anode of the center LED which should be sufficient, but am a bit unsure about the K2.
The idea is I measure the solder temp, use the datasheet Rthjs (junction->solder point thermal resistance) and input power to estimate the junction temp.
The GD datasheet gives Rthjs, but the K2 datasheet only gives me derating curves for various Rja (junction->ambient) values.
Any idea, app notes etc that can help me measure the junction temp for the K2 (and is measuring the anode of the GD reasonable)??
Phil
Phil
