I am going to put some headlights on my skateboard, so I bought a bunch of 10mm ones from LCK on a member's recommmendation. The foreward voltage is 3.2-3.7. However I don't really know how to hook them up.
The website says to use a 82 ohm resistor with a 9v battery, but the LED PRO program shows that I should use a 270 ohm. So I'm a bit puzzled.
I know my ARC AAA doesn't use any resistance at all, so how can I tell what battery configuration will let my run them unregulated? LED PRO also says I should use negative 14 ohm resistance with a 3v battery, and I've had one of the LEDs strapped to a CR123 for about an hour now and it's fairly bright and hasn't burnt out. Can I just run say 3-5 of them in parallel off a CR123 or maybe 3 NiMh AAs with no resistor at all?
