Truth time!270winchester said:The Pierce M-10 is slightly smaller than the P1, with 1000Mah or 400Mah settings, and adjustable optic.
TigerhawkT3 said:Truth time!
As measured with my personal set of calipers, P1, and M10i, here are the measurements:
Model:----Length:-----Widest Width:-----Narrowest Width:
M10i-------65mm---------23.2mm------------19.9mm
P1--------64.35mm-------20.5mm-----------18.15mm
So the P1 is actually smaller. Sorry, 270winchester.
However, they're really, really similar in size. The P1 is also a lot more available, a lot cheaper, and a lot simpler. I would suggest the P1 as a gift.
Orb Raw is RCR2 lightCHC said:The Orb Raw is one, but if that is still too "large" for you, then what MicroE suggested.
Enjoy!
I did, you were, and I will! :laughing:270winchester said:alright, congratulations, you spoke the truth, I was so very very wrong and I hope you sleep better because of that.
Abouna said:Is the P1 the smallest 123? I'd like to get one for a gift but I'm afraid even the diminutive P1 is a bit on the big side.
I've actually found the opposite. I've gifted several 123A lights, some with RCR123A and nanocharger, others with primary CR123As.jsr said:...For a gift to a non-flashaholic, I wouldn't suggest lights that require rechargeable LiIons (R123A, RCR2) like the FF3. That requires them to have the charger and remember to charge batteries. Most non-flashaholics I know just want to throw in a new battery....
