I'm setting up a 'twin cable' track light system in my living room, while attempting to buy as few parts as possible. I'd like to integrate LEDs into the picture, but I've got some concerns...
I realllly want dimming, because of the number of lights involved, and because I like to have a little mooood lighting, if you know what I mean. Most of the lights will actually be 12V MR16 Halogens, since I've got a bunch of the bulbs in a junk box, but I'd like to add some LEDs for color.
I've got an SCR dimmer pack I'd like to use for dimming, and a 12VAC transformer for the power supply. The SCR will be pre-transformer. The LEDs would probably be set up in small groups, with a bridge rectifier, a capacitor, and a resistor to create a fullwave mini-supply.
My big question is... How will these little LED/rectifier units respond to the SCR dimming? SCRs dim by delaying the rise of each half wave of the input, so, in effect, its a bit like a 120hz PWM. My thought is that the rectifier will continue to rectify, and that the cap will smooth this split sine wave into more of a DC saw wave. This should produce reasonable dimming for the LED. Perhaps a little more flicker than perfect, and a little more color distortion, but decent.
Is my vauge idea correct? Since this is a 'junk box' project, I want to purchase as little as possible, though I will need to buy some rectifiers. I'm not concerned about perfect performance, but I don't want to damage the LEDs (since, if they work, I'll get some Luxeon IIIs for it).
Thanks in advance for your suggestions!
-Sam
-Sam
