Van1,
Each lux will need V of approximately 3.5V. Each liion can only supply 3.6V. I assumed by using Mag 2C, you are connecting the batteries in series, which resulted in V of 7.2V - 7.4V
If you are connecting the lux in paralel, you gonna need a big *** load of resistor to help limit the current, otherwise you going to blow your luxes. Or a better way is to have a buck converter that will regulate the current to the luxes.
However, since the Vf of the luxeons might not be the same (even though they are from the exact same bin code), it is better to actually connect the luxeons in series.
If you do that, the total needed voltage would be approximately 11V. Clearly this is more than what your 2 liion in series can provide. Therefore, you need a step up/ boost converter to help bring up the voltage.
Fatman is a nice step up converter. I used one and I really like it. You can use external trimpot to adjust the current flow
Dat2Zip is supposedly coming up with a new converter, the SHARK, and that would also do the trick.
