Based on what I have seen so far, Fenix seems to use thread-lock as a way to tune in the focus.
A lot of components come together to locate the emitter in the reflector, and with all the tolerances something is needed to make a consistent product.
With the AA lights, they put a dab of thread lock inside the head and turn the pill down inside until it reaches position The epoxy cures and locks the focus.
With the AAA lights, they put the dab on the outside of the emitter collar. This is the "mid" section if you consider the reflector assembly is front and the battery tail is back. This is why the emitter collar is not always turned down fully into the reflector, depending on which torch you pick up. The earlier the emitter enters the reflector, the more of a gap they have to leave.
Knowing this, your can use this to your advantage. When you put your emitter in, it will probably focus at a different point than the stock emitter. Do the same thing Fenix does, tweak your beam to the focus you want and lock it into place.
