abvidledUK
Isn't it annoying when your torch doesn't have an indented head, so that when you stand it on end, no light escapes, making it hard to locate in the dark, when illuminated.
I have discovered that if you place such a torch, (not too powerful) head downwards, onto the clear / shiny side of a CD / DVD, you get a nice effect.
Basically, the light glows from the centre ring, and from around the edge of the CD, nice effect, just enough to slightly illuminate, and to make the torch easier to locate.
Main use, somewhere to place the torch whilst on the loo. CD on windowsill.
It works best when the torch is placed over the central hole, CD shiny side up.
It also works very effectively if you use the clear spacer "CD" packed with tubs & spindles.
And of course, the CD can also be used as a drinks coaster.
