Quickbeam
Expecting the contacts in any light to remain pristine without maintenance is an unrealistic expectation. Eventually you will have problems. Intermittent flickering, different output each time you turn on the light, etc. are all symptomatic of contact problems.
For those of you who are unfamiliar (I know many of you are already very familiar with this), Caig Laboratories, Inc. makes a product called DeOxit. It is about 20% cleaning solution, 80% preservative/lubricant.
You could buy the 100% solution (0% inert carrier) in a pen at Radioshack, but they were discontinued some time ago. You can now get DeOxit and ProGold in a twin pack at Radioshack, but the spray is only 5% solution, 95% inert carrier/propellent.
If you go to the Caig.com you can get the 100% solution in a bottle. I found the best value to the the 59mm bottle based on cost/oz. and my amount of usage. I suspect most folks will find this bottle will last them a long time.
http://store.caig.com/s.nl/it.A/id.1525/.f?sc=2&category=188
Apply with cotton swabs or foam wipes (foam is better - less chance of a stray cotton fiber remaining on the contact and causing issues).
Intermittent problems with MagLEDs, Streamlight Strion, etc. usually completely vanish when you clean the contacts with DeOxit.
Great product in my opinion, and not surprisingly, in the opinion of many of my readers who have written to me to let me know how well it worked for them.
If you don't need a cleaner per se, the 100% ProGold (now called DeOxit Gold) is 5% cleaner, 95% preservative/lubricant. This will help keep clean contacts clean. Again, avoid the sprays since they are only 5% product and 95% inert carrier.
I would recommend cleaning all your flashlight contacts with DeOxit per the instructions on their site. I've been stunned by the change in output. This is especially important for twist-friction contacts.
Don't forget to apply ProGold (DeOxit if dirty) to your battery charger contacts. Just leave a thin layer. You'll likely see a big improvement. I can't belive how nasty my charger contacts have become. Don't forget to clean the contacts on the batteries themselves!
