RipplesOfLife
If I wanted to dim the output of a single AAA, AA, or anything that have a boosting circuit (or any circuitry) with a resistor. Where should I put the resistor?
Like this: (between circuit and battery)
LED - Boost Circuit - Resistor - Battery
or like this: (between circuit and LED)
LED - Resistor - Boost Circuit - Battery
Does it matter?
I assume, doing something like this will lengthen the runtime???
One problem I see (assume) with the "between circuit and battery" setup is that at some point there will not be enough power for the circuit to work. Will the boosting fail sooner than if there was no resistor? Or will this happen after a longer time?
Thanks.
Does it matter?
Thanks.
